How to add mass to Pro/Mechanica Model
I am a Solidworks Simulation user that must migrate to Pro/Mechanica with the new job.
I am trying to add a 1 lb mass to a model. That is, I want to "smear" 1 lb over the face of the part. Solidworks considers this a distributed mass. I can not find the equivalent in Mechanica. I tried Mass Definition but it is looking for a Geometrical Reference. It will not let me pick any features on the part.
Any ideas?
Any ideas?
RE: How to add mass to Pro/Mechanica Model
Altering density would only work if you applied a shell element directly on the surface, but that would introduce shell-solid links - and that would make the model a bit messy.
When I left PTC 3 years ago there was talk of adding a distributed mass feature - so it might be there some where.
Hope this helps.
Like most FEA software, one needs to learn how to set up models and the PROCOACH lesson on Mechanica does not mention how to drive in FEM Mode.
I guess I need a better tutorial!
So just to be clear, when the FEM mode box is checked you are not actually using Mechanica.
Give the weighted links a try.
As a work around, I made a new material with an increased density to match the weight of the pcb plus the 1 lb.
I am only looking for the natural freq at this point and the above approach worked but was much more time consuming than just adding a distributed load like I could do in Solidworks.
