oil filled transformer data
Hi, I am starting to do some coordination work and I require some data. Does anyone know if you can get general oil-filled transformer data (%z, x/r, etc.) for units less than 5MVA without having to contact a specific manufacturer? This is for early design stage, which is why the exact transformer name plate info is not required. I've looked on google for a while without luck.
RE: oil filled transformer data
Eaton Info
And go to page 105 in the pdf.
