Mirroring sub-assemblies w/offset
I'm currently working on a V-engine and there is a similar sub-assembly on top of both banks on the engine. Is there a way to mirror this one sub-assembly to the other cylinder bank? And perhaps apply an offset to the mirrored copy?
Ideally, I'd like a mirrored and offsetted copy on the other bank. The copy should also be associative, so that if I add/remove components from the "parent" assembly, this change would inherit. Is this possible in NX?
Thanks!
Thanks!
RE: Mirroring sub-assemblies w/offset
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
