Contextual links
Contextual links
Contextual links
Using V5 R18.
I have a part that has lost its links. I normally activate the part, right-click/components/define contextual links. But this time "ok" is not available.
At the top of the define contextual link-box it normally shows the search string for the products in the assembly. Now it just says "Unknown context". What has happened? How can I fix it?
Thanks for any help...
/Fredrik
RE: Contextual links
You do have the part open within an assembly?  And you are in the Assembly Design workbench?
Do you remember which assembly you used when defining the contextual link?
Check EDIT + LINKS. Hopefully there will be a path & file name to the last contextual assembly.
Also, if the links you are trying to define were not published to begin with, you also have issues
