Ductile Iron Performance in Arabian Gulf Seawater
Hi All,
I'm looking for some refereces/advice on the performance of Ductile Iron ASTM A536-GR60 in Arabian Gulf Seawater (high temperature, high salinity), as a material for valves and penstock gates.
Thanks for your help.
Tom
Tom
RE: Ductile Iron Performance in Arabian Gulf Seawater
It needs an extremely good fusion bonded epoxy coating or rubber lining. Any damage to the coating may cause heavy corrosion.
You better go for 2507 Superduplex materials.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
