Boilers building internal explosion
I am modeling an internal explosion (natural gas) in a boiler building using Baker Strehlow explosion method. Any comments on how we should set the parameters, e.g degree of confinement( flame expansion) and obstacle density in a boiler building. building full of natural gas is considered souce of explosion.
Many thanks,
Many thanks,
RE: Boilers building internal explosion
"building full of natural gas is considered source of explosion" - not an explosive mixture until the molecule of O2 & ignition source are present.
not sure about "Baker Strehlow" method, but there are plenty examples of explosion in homes, commercial, and industrial complexes.
good luck!
-pmover
Go visit three or four.
The restraint against an internal explosion will be the boiler water walls and superheater pipe walls. a continuous double wall of extremely thick-walled high-strength pipe welded between each adjacent pipe. That pipe (if cold - the most likely time for a gas buildup and then explosion!) will be substantially below its high-temp yield strength and will offer both a large volume to hold the expanding gas as it tries to blow out and up the chimney, and a large "expansion" as it tries to deform from a four-sided flat-walled waterwall container into a balloon.
Gas expansion modelling of the explosion forces trying to get through the superheater tubes and the feedwater heaters/heat recovery system and exhaust dust collectors will be difficult.
Then again, if you have a natural gas explosion potential, you not likely to have a (coal) dust collection system.
