Equipment ground required between transformers?
I have a case where the utility feeds a customer owned 240:480 transformer, then there is about a 2000 foot run to a 480:120/240 transformer to a panel that feeds the load circuits. I understand this forms a SDS at the load end, but is an EGC required to be also run between the two transformers? I am finding conflicting information on this. Thanks
RE: Equipment ground required between transformers?
Also, you advise that (C)(1) requires an ECG between the transformers if not grounded, but then you say that (B)(1) requires an EGC if the secondary IS grounded.
As far as what it would be connected to at the secondary of the transformer, the code requirements for a grounding electrode at an ungrounded SDS are the same as those for a grounded one. See 250.30(A) for grounded systems and 250.30(B) for ungrounded systems.
Bill
"Why not the best?"
Jimmy Carter
In the 2005 and earlier NEC you were not required to run an EGC to the second building in all cases. Where an EGC was not required you would bond the grounded conductor to a grounding electrode and the second building and the EGCs for that building would originate there. Starting with the 2008 NEC, you are required to run an EGC to the second building and connect that EGC to a grounding electrode at the second building. The grounded conductor cannot be connected to the EGC or grounding electrode at the second building under the current codes.
Note, I had assumed we were talking about two structures, but in this case even if both of the transformers are in a common building the rules in the NEC would be almost identical and result in the same installation. That is a grounding electrode would be required at both transformers and an EGC would be required to be installed between the transformers.
Bill
"Why not the best?"
Jimmy Carter
The secondary of your transformer at the second structure is a SDS that is required to be a grounded system by the rule in 250.20(B). This requires the connection of the grounded conductor to a grounding electrode.
