ABAQUS/Explicit v6.9 - contact penalty algorythm
Hello there,
I have been working on a contact problem between a deformable body and a rigid plate. I want to try and use the penalty constraint enforcement method but the processor seems to give an error when I use the following:
*Surface Interaction, name=ContactProperties
*Surface Behavior, Penalty=Linear
Using Direct, or Penalty=Nonlinear seems to give the exact same mistake. The .dat file says the processor does not understand the additional command Penalty or Direct.
Has anyone experienced a similar error? Do you know how to overcome it?
RE: ABAQUS/Explicit v6.9 - contact penalty algorythm
I am only guessing, but both these option (direct, penalty) can be use only with Abaqus/Standard.
You did not write which Abaqus Standard or Explicit you are using.
Bartosz
Hello again,
Ok, my mistake You wrote it ... in post title.
So You have your answer.
Bartosz
