[NX 8] Custom symbol reference
custom symbol can be related (linked) to the master symbol, so if I change the original master, all referenced symbol can be updated to the change.
There is a setting / option that advise me that the part symbol must be updated because the master had changed, without to go to the out-of date folder in drafting and manually click on 'refresh' ?
For example, in the bottom of the drawing, NX say if view need to be updated, but symbol no.
Solutions or ER ?
Thank you...
Using NX 8 and TC8.3
RE: [NX 8] Custom symbol reference
AFAIK this works with drafting plus lic. I would still use pattern for this kind of symbols. I can not see the benefit of these new symbols and the out of date folder. Pattern update      immediately no update process to start.
Symbol are part of reuse library, not to drafting plus.
I like symbol in NX, but I'm looking for an help to know what is out-of date.
Thank you...
