Cat 3406E Service Info
Does anyone happen to have a service manual for a CAT 3406E engine, and the time to look up the following dimensions for me?
* conrod centers length
* main journal diameter
* main journal length
* main bearing clearance
* crank pin diameter
* crank pin length (bearing portion)
* big end bearing clearance
* piston pin diameter
* small end bearing length (top)
* small end bearing length (bottom)
* small end bearing clearance
Thanks...
RE: Cat 3406E Service Info
If there is a dealer near you they will gladly help, and or let you use the manual.
