Engine radiator performance
I am currently assisting with designing a large radiator for a diesel engine for >45°c ambient operation.
Could someone please assist me in calculating the ambient clearance of the radiator using a set of test data (coolant temps, BP etc) as I cannot find anything on the net at all!!
Many many thanks in advance!
Andy
RE: Engine radiator performance
Andyb86,
Normally the radiator performance requirements are specified the the engine manufacturer.  Typically, they would specify a coolant volume flow based on the jacket water pump, and one or more temperatures.  Those temperatures are typically on the order of 82 C in and 77 C out (this is typical for Caterpillar engines), but may vary depending on your engine manufacturer.
The engine manufacturer may also specify a jacket water cooling load.
Speco (www.stoneprocess.com)
