AWS d1.1 /RT acceptance criteria
help: according to Fig 6.2 for a 1" weld the maximum indication can be just over 5/16" , however if there are two indications at 1/8" in size they can't be closer than slightly over 1" , doesn't seem to make sense , i can have a indication 5/16" in size but not two 1/8" indications closer than 1" am I reading the chart correct.
RE: AWS d1.1 /RT acceptance criteria
That is how I read it. AWS D1.1 is very strict on adjacent indications. The only wiggle room would be if the two 1/8" indications are separated by less than 1/16. Then you could call them a single indication < 5/16 in size.
JR97
But I agree, is seems counterintuitive. In a few years [decades?], somebody will apply Fracture Mechanics to the D1.1 and D1.5 criteria. Expect a LOT of changes then, generally towards accepting larger flaws. Mild steel is very 'forgiving'.
