London Eye (ferris wheel): what are these things?
London Eye overview:
http ://files.e ngineering .com/getfi le.aspx?fo lder=47cbd a96-ca76-4 7bc-af79-3 26bbf9b33b 8&file =eye01.jpg
base for cables:
http ://files.e ngineering .com/getfi le.aspx?fo lder=4d582 6e3-7967-4 3ac-bbda-1 5355b6abe6 f&file =eye02.jpg
The London Eye is held in place by means of six large cables, which you can see in the thumbnail pics above.
On those cables, a special "weight"-like sort of thing is attached (see full res pic:
http ://files.e ngineering .com/getfi le.aspx?fo lder=1ac3d dc3-e75a-4 84c-b405-3 026c3d18a3 e&file =eye03.jpg ).
Anyone knows what they are/what they are for?
I've been looking at those for quite some time, and besides they're nicely aligned I have no idea whatsoever what they do...
only reasonable explanation I can come up with, is that they will rotate along the axis of the cables if they should loosen or unwind, but even that is very unlikely, besides there are other visible markers for that sort of things...
Thanks in advance...
kn.
http
base for cables:
http
http
kn.
RE: London Eye (ferris wheel): what are these things?
Cables are around 40 m long, and these are attached at ~2.5 m height.
Also, their weight seems negligible compared to the weight of the cable.
However, I suppose (and I sincerely hope, as I took a ride on the thing) that the people who designed this knew what they were doing...
Anyway the website below shows a similar if not the same product.
htt
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Mike Halloran
Pembroke Pines, FL, USA
