Thrust Block using
Thrust Block using
Thrust Block using
In which size of pipes or velocity of fluid should use thrust block on elbow?
RE: Thrust Block using
What fluid's mass?   Slurries can give a lot more thrust.
What kind of pipe?   Welded pipes usually don't need them.
What kind of flow?   Steady state might not need it, transient pressures might.
From "BigInch's Extremely simple theory of everything."
And is there a Positive Displacement pump in the pipe circuit?  Without a Pulsation Dampener, those pumps pound pipe hard.
May I add to Biginch question list the following:
What pressure?
What deflection angle (elbow angle)?
what cover height of the pipe?
restraint or unrestrained joints?
