Variable thickness with "Thick Surface" GSD function
Hello everyone!
I am currently struggling with something I'm pretty sure is possible. I have a complex surface in GSD and would like to thicken it with the "Thick Surface" function.
When I put for example 10 mm in the input it works. What I wanna do is set a 'law' or data table to tell CATIA to vary the thickness along an axis (of an axis system) so that my part has a variable thickness.
I've tried to use the "Law" or parameters but I can't figure out the way to do it.
Has someone ever succeeded in doing that?
Thanks in advance :)
Bye!
Bye!
