Solidification Cracking
Hi everyone.
My QC Manager wanted me to search for Solidification Cracking and find out when the Solidification Cracking takes place (when W/D < 0.7 or W/D < 1)? And what are the Parameters W and D?
Thank you for your help.
RE: Solidification Cracking
htt
May I ask another question?
1) How long does the Solidification Cracking take to appear after the welding?
2) To what thickness the Solidification Cracking occures after PWHT?
Sorry for bad English grammer.
Thanks.
Thank you in advance.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Thanks.
Reheat cracking only occurs during PWHT and can grow after PWHT based on tensile stresses in service. Normally, nondestructive testing is performed after welding or PWHT to avoid missing either types of defects.
PWHT has no effect on solidification cracking.
ΔG =Cr+3.3Mo+8.1V
and it was mentioned if ΔG<0 then the suceptibility to this cracking is low!! while ΔG can not be less than zero!!!
I need to know what is the proper formula if there is.
Thank you.
http
What is being mentioned is that when [delta]G[/delta] goes toward zero, susceptibility is reduced. The equation represents the heavy hitters that influence reheat or stress relief cracking. Yes, for carbon steels this can be zero - no chromium, no molybdenum and no vanadium!
http://www.theiiwmumbai.8m.com/defects7.htm
