franki piles capacity
We have a series of 16 inch frankies. Does anyone know typical structural capacity of these sections? Only so we can decide if its worth proceeding to more detailed investigation.
RE: franki piles capacity
We just had a set designed in the Boston area and the foundation company sized them for 88 kips compression and 64 kips tension.  They were also ~16" diameter.
It was my first experience with them.  The terminology with this company was to call them 'pressure injected footings' and they discouraged the use of 'Franki Pile' as "outdated".  Not sure why as it doesn't seem that uncommon.  Perhaps it was regional.
We completed a project with 16" dia. frankie piles.  I never agreed that they made sense for our light loads, but that was what the contractor wanted to do.  The axial capacity for our 16" piles was in the range of 500 - 1000kN.  The lateral capacity was about the same as any 16" diameter shaft pile.
If you have large axial loads, subsurface water problems and the equipment, I think they make a great deal of sense.
Brad
To try to answer azcat's query, Franki does a lot of different types of piling, so although the expanded base piles are commonly called Frankpiles, it could lead to confusion.
