piping strain issues
how can i eliminate piping strain from two acid condensate pumps running on same suction and discharge header after correcting piping strain then adding bellows on both suction and discharge lines vibration readings still high
RE: piping strain issues
What kind of pumps, centrifugals, recip?? How big, etc.
From "BigInch's Extremely simple theory of everything."
Johnny Pellin
If indeed the piping is vibrating then you could add pipe supports to prevent the piping vibrating.
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
Most pump vibration is a result of operating too far from the pumps BEP.
Based on field measured data, at what percentage of the BEP are you operating ?
Additionall, have you checked pump/baseplate anchorage ?
Are you certain that you do not have "soft foot" conditions ??
