gas spring design
gas spring design
gas spring design
i have done some searching online and can't find what i'm looking for.
i'm not entirely sure that it is possible but thought i'd pose the question anyway (out of curiosity)
a gas spring (doesn't matter if its push or pull type) with a hole in the middle - by which i mean so that it would fit around a cylinder, this might mean that it has to be longer than normal to be able to absorb the same amount of energy.
any help/comments welcome.
RE: gas spring design
Hi crazylazy
Any chance of a sketch
Hi crazy
Not seen anything like that as yet
Can you put two collars with three equally spaced gas springs attached.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
berkshire- that does sound like a very simple solution, that you for that.
very helpful desertfox! exactly what i was after!!!
