Rebar Splices at Construction Joints
Is it necessary to splice rebar at construction joints. The particular application is for concrete shear walls.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Rebar Splices at Construction Joints
Don't misread the answer to assume that you can terminate the bars at the joint - unless you are purposely making an expansion joint or a tensile separation between the two concrete placements on either side.
Just to be clear, it will be a horizontal joint in the wall. We will specify that the joint is roughened.
I assume that this does not change your answers.
In a wall pour, it's nice to limit the bar projections, as they are a little dangerous, plus they get in the way for the chutes or hoses or whatever.
For example, in canadian code, not more than only 50% of splicing can occur in the same location in the platic hinge region (that can be 3 story height) of a ductile shear wall.
Check you local concrete code.
