four bar linkage
four bar linkage
four bar linkage
Any ideas on a linkage to move a plate in horizontally (approx 6 ft) , stop, then raise vertically (approx 1 ft)  I would like to have one drive (linear actuator, etc) for both motions
Maybe some four bar linkage?  I cannot figure out a simple design.
Any ideas would be most appreciated.
RE: four bar linkage
Roller chain.
Mike Halloran
Pembroke Pines, FL, USA
Get hold of source of " transport mechanisms"
Onr reference I have is
Mechaninsm, JS  Beggs, McGraw Hill, 1955
which has quite a bit
Awesome ideas and advice.  Thanks.   I was not aware of all the information out on the web.
Thanks again.  Tony
I like analog solutions!
Three discreet positions define a 4-bar linkage.  If you know three desired positions, the linkage defines itself.
Look up "relative pole" methods for 4-bar design.
Who suggested to you that you use a 4-bar linkage to perform two simple linear motions?  Did they ask you to see how complicated you could make this operation?  Why not two simple motions and systems which performed the two functions you ask for?  Complicated design is generally not better design or less expensive design, and the only people it impresses are those who don't know any better.  What about simple design, operation, adjustability, and maintenance, they rule in the real world of an operating plant.  I wonder what would happen if you described your problem and what you were actually trying to do, step by step; size and weight of plate, does the pl. size or travel ever have to change.  Where does the plate come from and go to after the 1' lift?  And then asked the question, what would be some simple ways to do this?
