Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...An excellent site which has quite possibly prevented me from having a mental/nervous breakdown..."
Geography
crashnscar (Mechanical)
4 Feb 12 12:39
Making alignment/eccentric bolts and I'm not sure what material to specify as I'm not the best with materials.
Obviously going to be some steel, but how would I specify say a Grade 8 bolt steel?
KevinK2 (Mechanical)
17 Feb 12 13:00
pwildfire (Mechanical)
29 Feb 12 12:58
Grade 8 bolts are typically made from SAE 4140 steel. Any machine shop will have pre-hardened steel in this grade that will be approximately the same strength as an off the shelf grade 8 bolts.
29 Feb 12 14:09
I though B7/Gr5 were 4140, and A354-BD/Gr8 were 4340 or a similar higher alloy, to answer OP's direct question.
http://www.americanfastener.com/technical/grade_markings_steel.asp
1 Mar 12 8:51
Grade 8 and A354BD are both alloy steel with Tensile >150ksi, Yield >130ksi, and A354 stipulates >14% elongation. From Machinery's handbook, 4140 tempered to 900F will exceed all of these requirements. 4340 @1100F will be similar mechanically, but is less available, especially as a pre-hard bar.
I didn't have time to pull a cert and see what actual properties of as-recieved material are, but they are typically right in this area for 4140.
I don't recall off the top of my head, but I believe the chemistry requirements for these types of fasteners are pretty lax.
In any case, as far as the original question, 4140 Q&T is your best bet, as it is what most shops are likely to have on the shelf.
Tmoose (Mechanical)
2 Mar 12 12:24
Can't adapt one from a Corvair/Corvette/etc ?
http://www.ebay.com/itm/C2-C3-Corvette-Camber-Rod-Adjustment-Bolt-Kit-/350533242709
A buddy bought a set from a specialist and  the bolt head is "marked" with 4 lines all in a 180 degree arc, and ABW or BAW.
the eccentric plates fit nicely.
5 Mar 12 13:59
wildfire, he asked for Gr8, which I gave him. But for his application, I think the Gr5/B7 (4140 spec) is better, as it is likely to have less notch sencitivity, a good thing for a notched cam adjuster. Hopefully it will be torqued with enough preload to make a friction shear connection. Also, he could do as I have done; buy a larger Gr5 bolt from a hardware/car-parts store, and have it machined to spec.
Close Box
Join Eng-Tips® Today!
Join Us             Close
