Weld Quality Factor (E)
Hi All,
Would any of you be kind enough to confirm me the following.
If material of the pipe is A358 TP 321 Class 2 EFW
A358 Specifications Quote
"1.3.2 Class 2—Pipe shall be double welded by processes
employing filler metal in all passes. No radiography is required."
Then
For Piping Stress Analysis (B31.3)
Long. Weld Quality Factor (E) = ?
I am taking 0.7.
Is that right?
Tabby
Then
I am taking 0.7.
Is that right?
Tabby
RE: Weld Quality Factor (E)
