Balancing pipe
Balancing pipe
I have a mile long road with ditch on both side. 4 x-culverts are proposed which are tend to act as a balancing resorvoir (max 60" pipe d/s). Will there be any problem since the culverts will be submerged for few days (3-4 days) before the water is finally let go through flap gates. culverts have head walls. will the roadway structural integirity be compromised? any other problem that might happen in the future??
RE: Balancing pipe
not sure I understand why you would use flapgates on the x-culverts, that might prevent equalization. are the flaps on the outfall?
RE: Balancing pipe
RE: Balancing pipe
RE: Balancing pipe
RE: Balancing pipe
RE: Balancing pipe
