Creating gear trains? (more than 2 spur gears)
I have created 2 gears with 'Spur Gears Component Generator'. How do I create the next gear in the gear train? (compatible with gear #2)
RE: Creating gear trains? (more than 2 spur gears)
If 3rd is different than 1 or 2 create a second set adn delete the unneeded gear.
My problem is that I dont know how to make use of the automated compatibility in the design (via the Spur Gears Component Generator) for the 3rd gear.
I would go ahead and leave this as a Design Accelerator assembly if you might have a need to go back and change.
Grab one of the gears from the second assembly and place into the original assembly with appropriate assembly constraints. Should be trivially easy.
Post your files and requirements here if you can't figure it out.
