PMI + feature parameter
I'm looking at PMI how to add the thread dimensions to thread like feature parameters in drafting - what is the way to put this feature parameter to thread in PMI?
Thanks in advance
Thanks in advance
RE: PMI + feature parameter
BTW, a little known feature; if you go into the Expression system and you edit the String Expression which is tagged as the 'Thread Size' and you enter a valid 'thread size' callout string, this will be sufficient to edit the thread and ALL of it's parameters. What this means is that it's now very easy to control the size of a Threaded Hole feature from the Expression system without having to edit and update all of the numerical parameters indivually.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I thought about an automation getting the callout information.
regards
