Interpretation: VIII-1-89-227
According to this interpretation if I have smls pipe and a bolted joint at each end welded to the shell with a full penetration corner joint a JE = 1 is permitted.
What if my weld attachments on both ends are loose type flanges (slip on flange / double fillet)? Can I still use a circumferential and longitudinal E = 1 as stated in Interpretation: VIII-1-89-227?
RE: Interpretation: VIII-1-89-227
Additionally, this weld not being a butt-weld, no RT will be required.
