Cutting Plane Line
Cutting Plane Line
Cutting Plane Line
Hi all,
Just bit the bullet and upgraded to ST4 (from ST2).  Now just performing the 'tweaks'.
Question - When you creat a cutting plane, you can select the cutting plane line and go into its properties - in the general tab, the lower window 'display' shows the 'Style' the default is Thick, how do I change this default to Thick/Thin, to stop me having to change it manually all the time.
Any help would be gratefullt received.
RE: Cutting Plane Line
I believe you need to change it in your draft template file.
-av8errr
Solid Edge ST3 MP9
HP Z400 W3565 @3.00GHz
Win XP X64
15GB RAM
NVIDIA Quadro 2000
Thanks, Where is the option to change it?
you need to open the template draft file.
It is saved on your"c" drive.
look in program files, solid edge st4, template.
Open the draft template file that you use when creating new draft documents.
Then, create a view with a section line.
edit the section line settings as you want them to be.
save the draft template.
delete the view, and re-save the document.
Close the document.
Now create a new draft file and see if the change was saved.
-av8errr
Solid Edge ST3 MP9
Win XP X64
15GB RAM
NVIDIA Quadro 2000
thanks, just tried it, & id didn't work.
The other place I would try to make the change would be in styles.
Same deal here, edit the template file, but go into styles, and select line as the style type.
select cutting plane from the list, and click modify.
set the line weight to your preference, and click apply.
save the template file.
-av8errr
Solid Edge ST3 MP9
Win XP X64
15GB RAM
NVIDIA Quadro 2000
It's wierd, that linetpye is not specified, as it starts and ends with thicker dashes.  Starting to think it's not possible.
It's OK everyone, found under the Drawing View settings in 'Styles'.
thanks
