Reference set on single part in drawing
Hi
I have a problem when I try to create a view on a drawing. It is a single part that contains multiple reference set.
It is set up with the Master Model principle, where the drawing is normally based on one reference set.
In NX5 I could put on a view like Top and it would look like the reference set showed. And if I added another view, but with the *Top then I could select another reference set for this view in my assembly navigator.
But if I do it the same way in NX7.5, then I can´t change the reference set of the part in the new view.
How to show multiple reference set on a single part in different view?
It is set up with the Master Model principle.
We have just switched to NX7.5 from NX5.
Hope that there is a way to do this.
RE: Reference set on single part in drawing
So, as to your ability to choose different component reference sets of one component part when adding a drawing view, I am also very curious.
Technically, the glass is always full.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
