Deck spanning wall to long span joist
Consider a long span roof joist; say 70', parallel to a wall. The roof deck spans from a steel angle bolted/anchored to the wall over the roof joists. The bearing angle is obviously a rigid connection as it can't deflect but the bar joist can deflect 2"-3" at the center under live load. I have seen this detail and used multiple times but I was wondering if excessive deflection (very long joist) could create any issue with the roof deck.
RE: Deck spanning wall to long span joist
1)Compensate for the camber of the joist with the wall angle:
2)Specify the required camber for the end joist to be 1/2 the design camber.
This is similar to what Ron is referring to in his post above.
Thanks for the idea. Could be useful in the future.
SteelPE,
Actually the side wall is a percast panel. Instead of embed angles I asked for embed plates and the angle is to be welded in the field so I think it would be easier to match the camber. Also, the joists are spaced closer next to the wall 2', 4' and then 5' c/c. So I think the LL deflection from angle to the first joist should be minimal (probably 1-1.5" or less).
Ron - I don't think I understand the slot concept. Could you maybe elaborate?
Thanks.
EIT
