why two span continuous beam has negative moment at support
RE: why two span continuous beam has negative moment at support
Because the top of the beam is in tension.
Did you miss class that day??
A two span beam has three supports.  Which one ya talkin' about?
Please keep your comment positive.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Also what loading.....spans could be paritially loaded and not have full uniform load over both spans....
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
M^2
I agree with keeping comments positive - but that is basic statics!!!
i knew the answer that, for conti.beam, maxm. -ve moment is at support. and it is due to why....but i am looking for very specific answer, which i have not received. (regardless of tension and comp. what that causing it negative moment.) but anyways, i found it from one of reference book...thanks for keeping my quesiton at basic....
luharr,
If you have a question you should ask all of it. You question asked nothing specific but you want a very specific answer. We cannot read your mind so how can we answer a question that is not asked.
All you have done is wasted our time no matter what Mike^2 may think.
No all we really want to know is what was the real question!
MtE:
I think you missed my allusion here.  I was not referring to your answer about being "positive".  I was referring to statics, speaking with a forked tongue as usual.  bigsmile
Mike McCann
MMC Engineering
Sometimes - I can be very dense - just ask my wife
