aluminium chassi
aluminium chassi
I'm evaluating to build a front subframe using rectangular aluminium extrusions. I'm wondering if anybody did a similar work and have some suggestions/feedback to share.
I'm concerned about the suspension mounts. I would use stainless steel brackets to avoid corrosion, but I need to bolt them. My idea is to weld a small piece of aliminium tube through the rectangular extrusion and use it as a guide to pass the bolt through.
Any reccomendation ?
here is something similar on Audi R8 rear suspensions:
h ttp://stad ium.weblog sinc.com/a utoblog/hi rezpics/W8 _cutaway_l arge02.JPG
h
RE: aluminium chassi
http://www.lotuscars.com/engineering/en/index
Is this just for a one off?
The big issue is softening of the HAZ .
Cheers
Greg Locock
