Rectangular plates subjected to a concentrated moment
Folks
I'm looking for the easy option here. Does anyone know of a reference for the anaylsis of rectangular plates with an applied moment (trunnion loading).
The old faithful Roark has a case for circular plates (6th Ed, Table 24, case 20 and 21) but no such for rectangular plates.
I could approximate by reducing the applied moment to a force couple and using the concentrated loads (one positive, one negative) and the superimposing the results, or go back to first principles and brush up on my differential equations.
Or, ask all the nice folks here if they know of a resource that would mean I didnt have to.
Cheers.
Cheers.
RE: Rectangular plates subjected to a concentrated moment
If your trunnion is on a base plate supported by grout or concrete, that approach is likely as good as anything. The Roark cases you referenced are with the plate supported at the edges, which is an altogether different load arrangement. Generally, with a small trunnion and large plate, I would assume that stresses were much higher near the trunnion, so checking bending across the plate width wouldn't necessarily give you a good indication of stresses near the trunnion. In that case, the Roark cases would probably be more appropriate.
Thanks folks.
www.bowerseng.com
you could always replace your moment with a couple, maybe 1" apart ? unless the load solutions assume a central load ...
Are you considering the circular portion of plate within the trunnion to do a rigid body rotation, i.e. the trunnion is infinitely rigid.
If you are just looking for a safe design, you could use an approximate method of analysis but if you require an elastic solution you will have to resort to more sophisticated methods. The Navier solution comes to mind, but I would need to read up on it as I haven't used it in about fifty years.
BA
I think for this case I would consider the circular section at the interface between the two to rotate the same amount as one.
I had already read up a little on the Navier solution in Timoshenko theory of plates and shells. I think it would take me some time to develop a solution from first principles. I suspect I will approximate a solution using a couple of hand calc approaches and then use a small analysis model as a comparison.
BA
That is a sketch, but confusing at conveying any real meaning, I imagined that much. I suspect that what BA meant when he asked is it to scale was, are the proportions reasonably accurate. I can see where he arrived at his 250mm trunnion dia., I made the very same guestimate, and I doubt that he was worried that it might be 240 or 260mm. But, now you leave me confused, because if it is only 60 or 80mm, that proportion change does cause one's thinking to start to change. Furthermore, with the way you have shown your moment, and used the term rotate, I am wondering if the trunnion is loaded like you might twist it as a shaft, thus a uniform shear flow btwn. the plate and trunnion; or is it loaded as a cantilever beam with some load parallel to the plane of its base plate and causing a bending moment in the base plate, thus a shear load and a varying bending stress over the trunnion's dia., and induced into the base pl.?
How much longer would it have taken to show correct proportions, length and dia. dimensions on the solid/hollow trunnion and a load vector out at its tip, or some point on its length. Think of how much more info. that would have conveyed. You are the one who want some help, so don't leave us guessing at your detail. BTW, I do think your approach of some simple hand calcs. and a little modeling is the right approach, but only you really know what the loads and boundary conditions really are.
can all four sides react the load, or only a pair ?
The dimensions are correct, apologies for not including more. The diameter of the trunnion is 225mm. On second viewing of the sketch I see why you thought it may be an applied torsion. It is a shaft cantilevered off the plate. It is actually a tubular.
However, it is not for me to ask you guys to do the design on my behalf, which is why I did not want to provide you with all the information in case I overcomplicated things.
But since you asked. I am looking at a design of a structural pipeline bulkhead in a PLET (pipeline end termination structure). The bulkhead is a forging specfically shaped to fit into the PLET structure. The structure is the second end structure (meaning it is the last thing laid down) and is suspended from the installation vessel through a wishbone yoke onto a wire. Hanging of the back of the PLET (supported by the bulkhead) is approximately 800m of pipeline. The load in the bulkhead is the tension transferred through the pipeline back to the vessel and a moment due to the installation. The moment is a function of the the catenary action of the pipe, the hydrodynamic loading on the pipe and the structure and the motion of the installation vessel. We get the loads from the installation analysis doen by the analysts.
Just to enforce the point, I am not designing this instead i am reviewing a design and I'm trying to get into the same ballpark using some simplifications. Once again, apologies for being vague but initially all I was asking was whether anyone was aware of formulae for a rectangular plate subject to a concentrated moment.
this bulkhead fttg has to be an industry standard, no?
Moody (Engineering Monograph 27) is still available online. he does consider a moment applied to the free edge of a plate. my 2c would be either ...
1) compare to existing designs,
2) model up something to compare with Moody, then model what you really want.
it'd be interesting to see how they calc'd the moment (rigid support or flexible support) and then see for yourself (whether the plate is rigid or flexible) ...
I believe that a the pipe and a 225 dia. section of the plate will do a rigid body rotation under load. The magnitude of the deformation can be assumed as +1 at the top and -1 at the bottom. Any point between will deflect linearly, so the mid-section of the pipe deflects 0.
I would draw assumed yield lines and equate the internal and external energy to solve for the moment per unit length of the plate. You may have to try several patterns because Yield Line Analysis is a lower bound solution but that technique should provide results accurate enough for your problem.
BA
It would simplify the problem if you assume a square tube instead of a round one. The sides of the tube should be about 0.8*dia. This gives a better indication of where the yield lines should be placed.
BA
What is the applied tension?
How can the applied moment be known without knowing the plate stiffness?
BA
BA
The applied loads are passed to us from the analysts. They make a number of assumptions about the stiffening effect of the structure on the pipeline during the installation, from this they provide us with the loads to be carried. The loads are determined based on the stiffness of the pipe and the structure. The analysis is carried out using a piece of software called Orcaflex.
This structure is the second end structure which means it is the last thing laid down. At one end of the structure you have the pipe running into the bulkhead, at the other end there is a yoke onto which the vessel wire is attached. So the attachment point of the yoke is the 'pin' as its purpose is to allow free rotation of the structure during the lay process. The load in the wire changes during lay, as does the angle. All of which varies the load on the bulkhead. So the wire is eccentric to the bulkhead. All of the load is transferred though the structure back to the yoke.
BA, you are correct that the loading will be a combination of the two. In this case the applied tension is of the order of 1500kN. The bulkhead forging is 150mm thick. So thin plate theory isn't really applicable anyway.
The more I think about it, the more i think that simplication isnt the way to go. Perhaps my best course of action will be to use an FEA based method as I am beginning to come to conclusion that the simplifying assumptions to allow me to do hand calcs will render them fairly useless.
M = 200 kN-m
T = 1500 kN.
eccentricity = 200/1500 = 0.133m or 133mm
Conservatively, you could consider a point load applied at that eccentricity, then determine stresses using Roark or determine ultimate load using Yield Line. In that way, you would be considering the combination of moment and tension as one eccentric force.
BA
Mf = phi*Fy*Z
For 150mm plate, Z = (150)^2/4 = 5625mm^3/mm
Mf = 0.9(300)5625 = 1.519e6 N-mm/mm or 1518kN-m per meter of plate.
Applied force, P = 1500 kN Pf = 1.5*1500 = 2250 kN
For a concentrated load at middle of simple span of 0.75m,
Mf = PL/4 = 2250*0.75/4 = 422 kN-m
Width of plate required to resist Mf = 422/1518 = 0.278m or 278mm.
If load is moved 133mm from midspan,
Mf = Pab/L = 2250*242*508/750 = 369kN-m
which is less critical than load at midspan.
Plate is adequate even on the conservative assumption of a simple span.
Using Yield Line analysis, I found the plate needs 278kN-m per meter of width for a concentrated load applied 133mm off center.
BA
BA
