Short Circuit calculations with site rated gas turbines
I am working with a gas turbine gen set and I have some questions regarding Short Circuit calculations and Short Circuit power.
The turbine has a site rating of about 12,5 MW (15,6 MVA) and a ISO rating of about 15 MW (18,5 MVA) power factor of 0.8. The alternator is rated 18,5 MVA.
So when I calculate the SC rating I use the alternator name plate rating of 18,5MVA.
My question is, will you always get maximum SC current independent of the turbine output? Or do I have to have ideal circumstances where the turbine gives the needed mechanical power?
If the current is dependent on the mechanical power from the turbine, can you detail?
RE: Short Circuit calculations with site rated gas turbines
Power equals current times voltage times power factor.
In the event of a short circuit the voltage may be very low so the power or MW requirements are lowered.
The short circuit current is very reactive so although there are a lot of KVAs, when that is multiplied by the low power factor resulting from the reactive current the KW or MW demands are lowered.
I would use the alternator rating for short circuit calcs.
Bill
"Why not the best?"
Jimmy Carter
