Adding an Inch symbol (") into a string expression
Okay, so I am working with expressions, and have a need to type in   4.25" into a string expression, but it thinks that the " is part of the string statement and gives me an unmatched error. I have also tried to insert it as a char( " ), but I don't even know if that is correct as I have not been able to successfully use it.
Thanks!
RE: Adding an Inch symbol (") into a string expression
Change the expression to read:
CODE
"4.25" + char(34)
OK, try using...
"4.25"+CHAR( 34 )+" TYPE 50 PIN"
...as the value of your Expression.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Okay, I figured char( " ) that nx gave me when I used the formula thing wasn't correct. And I was also trying to use & instead of +
Thanks!
