how to apply critical tolerance stack up analysis for large structures
hi,
I woule like to apply tolerance stack up analysis for large subsea structure on which a various modules/assemblies mounted & all modules should be 100% interchangable.
Can any one suggest me which method & how tolerance stack up analysis can be applied to this type of structural work ?.
so i can get final result in terms of Spreded excel sheet with mathematical relations (final intention) in excel cells.
RE: how to apply critical tolerance stack up analysis for large structures
i have done modules in onshore not offshore. we dont have this tolerance stack up analysis. we just oversize those base plate holes per AISC.
Mech123456,
   Your diagram looks like a bunch of modules bolted to a platform.  It looks to me like your primary requirement is that mounting holes line up, and that your interface structures are flat enough to not warp anything.  I do not see a stack anywhere.
   You need to prepare drawings with tolerances.  The holes have to line up.  Each module must fit within its envelope.  This is a better question for forum1103: Drafting Standards, GD&T & Tolerance Analysis.  It's not really a structural question.
   If you re-post, please red flag this thread.
               JHG
Assigning tolerances is a meaningless excercise if you don't know your process capabilities...
