Drawing Default View
Hello SW people:
Is there a way to change the reference model for the default view in a drawing?
I know of a work around where you insert a view hide the view the set the hidden veiw as your driving view. But there must be another way.
-Caper-
-Caper-
RE: Drawing Default View
Sorry for my vagness.
in sheet setup (properties)at the bottom of the window it says "Use custom property values from model shown in"
I want to change the default to another model rather than doing the work around.(see first thread)
thanks for the effort
Go to the model set your model the way you want your front view to appear in a drawing.
Then click the space bar (this brings up "View Orientation"), If you click the middle Telescope, this will update your standard views.
You have to define the model using the front view. It is the driving view for all views in the drawing.
HTH,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
Unless you're making a cut-sheet type drawing where your picture (the view) is not the actual part, but only a representation.
Like in a vendor catalog for motors, gearboxes, bearings, etc...
If you can clarify more what your trying to do, maybe I can give you more specific advce.
Is this an assembly or a part drawing?
Do you want another part alltogether or another configuration of the same part?
In this forum, there's no such thing as being too descriptive.
"Gloom, despair and agony on me. Deep, dark, depression, excessive misery. If it weren't for bad luck, I'd have no luck at all. Gloom, despair and agony on me."
Hee Haw
thanks for all your coments
-Caper-
Maybe someone else can "crack" this one.
Hee Haw
Scott Baugh, CSWP
BBJT CSWP
BBJT CSWP
BBJT CSWP
