Independent Geometry
We have just gone to WF 4.0 from WF 3.0.
In wf3 we use to convert non-solid geometry to independent geometry to be able then to use the "redefine import" on it.
What I mean is that proe was treating an independent geometry feature as an imported feature. In wf 4 although you can insert and independent geometry and collapse features into it, it is no longer treated as an imported feature. When you redefine it you do not get the same options as you would get on redefining an imported feature.
Is this how it works or is there an option or something that needs to be set?
Joe Borg
