set surface contact type " Bonded " in patran
Hi, Everyone
I have a question that
How to set surface contact type " Bonded " (as in Ansys) in patran ?
Could anyone guide me please.
Thank in advance
Best Regard, Charoenpon555
Thank in advance
RE: set surface contact type " Bonded " in patran
Assuming it's Nastran or Marc, you should look create "Glued Contact". Define deformable contact bodies (under Loads), then set as "Glued" in the Contact Table in Analysis setup. Contact Table found under "Subcases", "Subcase Parameters" for Nastran Pref.
