commercial kitchen cooling
I am stumped about a restaurant kitchen that has 3 stoves and a exhausted fan that is removing the heat from stoves when in use but is also removing the air being supplied to the room by a.c.Any suggestions.
RE: commercial kitchen cooling
The most common method is to add a swamp cooler with a dedicated duct right into the kitchen.
Most often you are just trying to get the sensible heat down.
Set it up so that the workers can turn the waterpump off when it gets cool outside.
You also want to make sure kitchen doors are kept closed so that you do not pull the conditioned de-humidified air from the resturaunt.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
IMC 506, 507, 508
