Decifering the European Rating System
Hi folks I work at a lighting manufacturer in the US and I am looking for the meaning of the european rating symbol IP and what that really means in terms of wet location. In other words, how much moister can it handel? Are there different levels of the IP rating?
If someone could explain this to me, or direct me to where I might find this information, it would be most appreciated.
Thank you.
Please reply to jdhirsch@seagulllighting.com
Thank you.
RE: Decifering the European Rating System
I hope the following answer could help to clarify your questions.
Q1-Meaning of the european rating symbol IP.
A1-IP stand for "Ingress Protection".
Q2-How much moister can it handle?
A2-Check the following Standard and references bellow:
1- NEMA Std 250. (See Appendix A) Enclosures for Electrical Equipment (1000 Volts Maximum)
2- IEC Std 60529: Classification of Degree of Protection by Enclosures
Q3-Are there different levels of the IP rating?
A3- Yes. The IP rating system classifies the degree of protection from solid objects and liquids afforded by electrical equipment and enclosures similar to NEMA.
Beware that NEMA standards meet or exceed IEC standards; therefore, you could convert from NEMA to IEC, but the conversion does not work in the opposite direction.
REFERENCES:
http://www.canarysystems.com/nsupport/canary_an4.pdf
http://www.reliance.com/prodserv/standriv/appnotes/d7745.pdf
http://www.dancon.com/techsup/nema_and_ip.htm
Christopher Caserta
ccaserta@enorthhampton.com
Ph:904-225-0360
