Invalid File Name NX7
Hi
I have a problem when I share a parasolid file with other user, actually I have NX8 and the other user has NX7., when the user open the parasolid file and try to "save" or "save as" (.prt) one message appears "INVALID FILE NAME". I proved the same file in my work station and it works well.
Some one of you know why appear this message in NX7, when I try to save the file in .prt?
Thanks in advance
Tom
Thanks in advance
Tom
NX 8.0.0.25 64bit
RE: Invalid File Name NX7
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
Ben Loosli
John R. Baker, P.E.
Industry Sector
Cypress, CA
Attached image for the problem, apologize for the delay
Tom
NX 8.0.0.25 64bit
As a check, try opening that Parasolid file in NX 8.0. I except that it will open just fine.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I made a test using another workstation with NX7 and the file (*.x_t) worked without problems, we will to re-install the NX7 in the lap top where we have the problem.
Tom
NX 8.0.0.25 64bit
John R. Baker, P.E.
Industry Sector
Cypress, CA
We re-installed the NX7 and we can save and load (*.x_t) parasolid files without problems.
Thanks a lot for your comments
Best regards
Tom
NX 8.0.0.25 64bit
