How to use the draft body feature to fill an undercut in NX8
Hi all,
I'm having a problem with one of the NX8 CAST tutorials. This tutorial can be found in the CAST library under "Feature Modeling", "Draft and Scale Bodies", "Draft Body", and the activity is "Fill undercut regions". I followed the directions exactly, however when I go to create the feature I receive a "Failed to construct draft" message.
Does anyone else have this problem also? Can anyone provide some insight?
