AASHTO LFD Composite Deck / Negative Moment Region Question
Hi all - I am designing a bridge where the concrete deck is composite with the steel stringers and am using LFD. Per AASHTO 10.50.2.3 in AASHTO 17th Edition, it mentions that the min longitudinal rebar must be 1% of the concrete area when the longitudinal stress in the concrete slab is greater than 0.9 x mod of rupture.
Can anyone provide guidance on how to calculate this slab stress? I always thought that in the negative moment region, the slab is assumed to not contribute any tensile resistance (tension = 0).
I figured perhaps to calculate the rebar tension but all the sources I see indicate to set the rebar tension to Fy x A rebar. Thanks kindly for your help.
RE: AASHTO LFD Composite Deck / Negative Moment Region Question
