Finding CG of Assembly in Inventor
I have an Inventor assembly with lifting lugs.
I want to determine at what angle will my assembly rotate as it is lifted from the lugs.
Help appreciated.
Help appreciated.
RE: Finding CG of Assembly in Inventor
It's a Bucket like component 10' long. I did initially include a pack n go of the model assembly name is Bucket-1.asm
It's a simple component but I just couldn't find how to locate the CG in the Assembly.
Thank You
I actually wanted to find out what it does when I lift it from the lugs. Where the new CG is relative to the movement caused by the lifting from the lugs.
Thank you.
