Differing Base Metal Material
I have read through D1.6(2007) to see what welding 316L(A312) to a D1.1 Grp I or II material covers. We have a procedure for 316L to A36 but have a job coming up that requires 316L to A572 gr.50. I know that, with the engineers permission, you can test welders on Grp I and II material with the alloy filler but cannot find if that is true for the procedures. Is it necessary to have a procedure tested for each and every Grp I/II base metal to the 316L?
RE: Differing Base Metal Material
Thanks!
