Corrosion Probes
Corrosion Probes
we need to provide corrosion probes in a gas service pipeline. it's sweet gas service.we had provided simlar kind for Sour gas service. But i'm not sure why we should be using them for Sweet Gas service. Can anybody please guide me thru that? Thanx in advance
RE: Corrosion Probes
You should find out the source of your requirement. Who give this comment to you? It's not necessary for me to add corrosion probe in the existing system if there is no trend of high corrosion rate.
You could also use dewpoint monitoring to determine whether you have the free water for corrosion, although I have heard of that not working very accurately.
Out of interest what type of corrosion probes have been specified?
