Removing Quotes from String Expression
I was wondering how you would remove the quotes on an expression. I want to use the string to populate the part attribute and then use that attribute to populate a parts list in another file.
Thanks in advance!
RE: Removing Quotes from String Expression
What version of NX?
Do you have a current workflow for this process? If so, what is it?
Have you created a part attribute from the expression? and the quotes show up in there? and in the parts list?
What version of NX are you on?
Sorry I even told myself I wouldn't forget to put that, 7.5.5.4
We are trying to get most of our stuff automated and we are at the very beginning of that process, so I am trying to make this fool proof by bringing ever expression up to the top level drawing.
I am trying to create the workflow. Basically it is a pin assembly, that includes a Pin, Retainer, and Retainer Pin.
The individual components feed an assembly file and the assembly file will feed the drawing file.  The drawing file will automatically populate using the attributes of the assembly files that are added. Does that help?
Yeah Jerry, the quotes follow it all the way through to the parts list..
can you show us what the expression looks like?
As you try to define the workflow, what have you tried so far; specifically, how are you getting the string expression into the part attribute?
What happens if you change
CODE
ug_setpartattrvalue("PIN_PMID", stringvalue(PIN_PMID))
to
CODE
ug_setpartattrvalue("PIN_PMID", PIN_PMID)
Genius!  I was just copying and pasting all the code and didn't pay attention to the fact that it was already a string!
