Are drains required in all rigid metal conduits per the NEC?
NEC article 225.22 seems to indicate that drains are required in outdoor conduits. If so, I wonder why this requirement is not in Section 344.
RE: Are drains required in all rigid metal conduits per the NEC?
The rule in 225 is a more general rule and applies to all raceways run outside.  What I don't find is a rule that requires a drain for raceways that are run in interior wet locations.
There is a specific rule in 230.53 for service raceways and a rule in 368.23 for busways.
Regardless of rules, you need a drain anywhere condensation might form.
Good on ya,
Goober Dave
Haven't see the forum policies?  Do so now: Forum Policies
Oops, sorry -- I posted too quick.
If no condensation expected, no drain required. So not all rigid needs one.
Good on ya,
Goober Dave
