using Bernoullis Equation to get flue gas flow rate inside pipe
hi
i am doing a project where i need to measure the flow rate of hot flue gasses (co, co2, nitrogen). i have took the pressure inside the heat exchanger mounted on fireplace rather than having flow velocity. then i use bernoullis equation as following to get flow rate.
Dia of pipe= 51mm
inner dia = 38mm
Corrugated pipe
pressure 300 pa
to find velocity from pressure (Bernoulli equation):
(po + p1) + rho v1^2 / 2 = (po + p2) + rho v2^2 / 2
where
p - pressure
v - velocity
1 and 2 subscripts indicate initial and exit values, while po is atmospheric pressure
(there is no height term since the pipe is horizontal)
if we assume that v1 = 0, and p2=0 (pipe exit)
v2 = sqrt (2 p1 / rho)
where p1 = 300 Pa
rho = 1000 kg/m^3
v2 = 0.77 m/s
Flow rate:
Q = A v2 = (25.5^2 pi / 4) * 0.77 = 393 m^3/s
result seems to me so weierd. it should not be so much high. can any one have any idea where i went wrong or the results are good enough.
thanks
Dia of pipe= 51mm
inner dia = 38mm
Corrugated pipe
pressure 300 pa
where
p - pressure
v - velocity
where p1 = 300 Pa
rho = 1000 kg/m^3
v2 = 0.77 m/s
Flow rate:
thanks
RE: using Bernoullis Equation to get flue gas flow rate inside pipe
From "BigInch's Extremely simple theory of everything."
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
i also tried micro manometer to find flow rate but the difference between these results vary. so i am not sure about the compressible flow parameters.
Nuclear- can u post the same cran's technical paper here or any link i tried but could not find it
Here's a link to the webpage where you can buy it: http://www.flowoffluids.com/. You can also find it on Amazon (and probably on e-bay), though for MUCH higher prices (even when you take shipping into account.)
IMO, it is well worth the price to buy it.
Patricia Lougheed
TTFN
If a compressible fluid, it needs to be the density of the fluid at flow conditions at the point of interest.
